cm.VSM.AppDataNotFnd
Description
This message indicates that the client ISC application has not been found. In such a case, CM's MLAG mode functionality will not function properly.
Remedy
This is a rare condition which may be related to software, and may require a reboot of the switch to correct the problem. If it persists, contact technical support and provide outputs of 'show switch', 'show log'.
Severity
Error
Message Text
Client ISC application data not found %isc%
Message Parameters
Name Type
isc uInt16
